73 and newer gas tank?
Discussion in '40- & 55-Series Tech' started by kenai, Aug 16, 2006.
  1. kenai
    kenai
    248
    Aug 14, 2005
    I got a new gas tank to go in my 69 cruiser from ccot. Its the later model interior tank. I believe the outlet on the drivers side of the tank remains the outlet to fuel pump. What about all the others? anyone know which is the return? thanks!
    heres the link to the pic of the tank
    http://coolfj40.stores.yahoo.net/gastanfj19th.html
  2. fj40charles
    fj40charles
    3,089
    282
    Dec 7, 2002
    Texas
    Can't help with install, but I do know that you want to really clean out the plastic burrs out of the tank.
  3. kenai
    kenai
    248
    Aug 14, 2005
    from all the searching i get different information, anybody an expert?
  4. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
    The fuel 'out' is on the lower rear section of the tank, towards the driver side, it is a hose barb fitting, NOT on the side of the tank facing the driver side...that is the return. If you hook up the return line as the fuel out, you will only be able to use half a tank before you starve the engine for fuel, even though, you have half a tank left....
    Good luck!
    -Steve
  5. Poser
    20,384
    Media:
    17
    Albums:
    1
    757
    Oct 1, 2003
    MN
    According to these pictures, the fuel out and return fittings are taped off...
