72 FJ40 upper rear shock mount move for s10 tank
OK
1972 FJ40. It looks like I need to move the upper shock mount/crossmember forward about 3" to make room for my s10 tank to mount without rubbing. Anything I need to be concerned about? Is there an easy way to replace the frame rivets without taking the cab off the frame? I heard I should weld it so it can flex some. Also the angle of the new shock mount? just try to keep it the same? I ordered OME 2.5" lift for it, will do at the same time. Any suggestions would be appreciated. thanks in advance! I'm not going to do any xtreme rock crawling. Joe
KY
I think that others have not had to move the crossmember to install a S10 tank. Try doing a search and you will find the info you need.
