- Joined
- Apr 14, 2004
- Threads
- 1,462
- Messages
- 36,599
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
So you’re not concerned about WHY the bolt broke?
Isn’t anyone curious as to WHY the bolt broke, and what made the shaft move? That bolt is not under a load...unless something else is wrong.
I’ve rebuilt hundreds of transfer cases ( I’m rebuilding 3 in the shop right now) and when the inside of the idler gear and/or the bearing surface of the shaft are compromised, THAT is when the lateral load on the shaft starts that ends up snapping off the bolt. Torque over time also slowly wallows out the hole in the case that the shaft sits in, compromising the interference fit of the shaft.
In other words, you are only addressing the symptom, not the problem.
If you took a sample of Mark’s blood ^^^^ you’d likely find he has Cruiser DNA mixed into it. I believe you’ve got lucky. If you don’t find the cause, you’ll be the one having it grenadine at 60 mph.
Dig deeper.
You are the proud owner of a chain looking for it’s weakest link. Unless you know the history of the case, there is no reason to assume anything good. And a glued on bolt head should be a![]()
Makes sense. Given all of your experience, do you have any insight regarding what signs, inside the t-case case, I should be looking out for? Like I mentioned earlier, to my untrained eye, all seemed to be well. You mentioned in your earlier post that lateral load on the shaft ends up snapping off the bolt In question... And that: torque over time also slowly wallows out the hole in the case that the shaft sits in, compromising the fit of the shaft. The shaft firmly sits in the holes on either side of the case. No vibration, sound or perceivable movement. What am I missing? If you don't mind: please give me a hint as to the expert diagnosis process with this problem.
You should disassemble the case and inspect not only the shaft, but the inside facing of the gear for pitting. These are not things that you can see without taking the case apart, but are things you SHOULD know about your ‘chain’.
By the time you’re there, you will have exposed all the other standard wear points.![]()
If it will make you feel any better, years ago I was on the Fordyce trail and the guy behind me said I was leaking gear oil. Pulled over and sure enough, gear oil all over the place. The end of the idler shaft where the retainer sits had broken off and the shaft moved forward, pushing the plug part way out. The only reason it couldn't move more was it hit the Downey 700R4 adapter plate. We were able to pull the side cover and use two bars to manipulate (coax) the shaft back into position. We used a bolt in the end of the shaft, washers and the OEM retainer and bolt to keep the shaft in position and get home.
Moral of the story? The thrust washer dropped out, but we made it out, at the cost of a chewed up t-case. It's worth the piece of mind to make sure everything is where it belongs. A garage is a much better place to check than on the trail.
