'71 Pig, how do I access the heater controls?
Is it possible to remove the heater controls (heat hi/lo switch and fresh/recirc lever, heat/defrost lever)? I'd like to troubleshoot my 2-sp heat switch, and also gain access to the fresh/recirc cable, whose housing is clamped in place with an inaccessable phillips-head clamp screw. I can see it with a flashlight thru the radio hole.
Mine has the dash 4WD apparatus all still in place.
Seems like the whole panel should be removeable, or at least the levers should be removeable from the backside, but how do you remove the plastic "knobs"?
It's been awhile but on my 77 the heater controls pull straight off (you may have to pry a bit) and the other round knobs had a hex head screw which is recessed.
Look under the heater controls, there should be a slit that may help in removing.
The knobs that run electric circuits will have a small flat head screw holding the knob on. Remove it and then screw the knob off. Then remove the flat captive nut holding the switch to the dash on the face. Then the switch falls into the dash, unplug the harness and retrieve it. The knobs that control cables, i.e fresh air, choke, and throttle will have a nut on the back holding the knob to the dash. Loosen that then loosen the end of the cable either at the choke, or in the fresh air damper and then pull the knob and cable thru the dash. Make sure you keep an eye on the nut so you don't loose it in the process.
Jeremy
Sounds like standard stuff, yes, but the (2) "lever" mechanisms are what I want to remove, and I can envision the plastic knobs pulling off, but, being levers, there can't be any big flat nut underneath to hold them in.
That's why I can only imagine that the whole PANEL is removeable, and maybe the lever mechanisms are integral with the panel?
I guess I'll do what I always do, go out in the cold with a trouble light after the kids go to bed and lay flat on my back on the driver's floor and try to see what I can see. Thanks for the responses, just thought I'd fish for that (1) guy who just did it last week...
Are you saying that you want to remove the lever that actuates the 4wd? If so you will want to remove the ashtray and probably the heater/air box to get under it and to get a wrench behind the dash. The lever is attached to a rod that will need to have a nut loosened closer to the ashtray. Once you get all the fasteners removed it slides out from a bracket torward the steering column. Kind of a tight fit, and took me a while to remove it. Not sure about the second lever you are refering to. Maybe the E brake lever? If so why would you want to remove it?
Jeremy
I think belmont is giving instructions for an fj40, or a later pig. on the 72 pig I have, you have to pry a little tab down on the back side of the plastic knobs, its a pain, but it sorta detents them on the levers. after that I think I unscrewed the trim piece, them you can remove the whole heater control deal with the funky lever/switch deal... its a pain, thats for sure. some of the other switches are just as bad, seems like you need a flathead that is about 1/2" long...
Belmont148, you've touched on a subject I've wanted to address for a while, but first:
No, the levers I was referring to are the heat fresh/recirc and heat/defrost levers. The former has an erratic switch and a frozen cable, the latter has a gummed-up mechanism I just want to remove and clean up. Both levers are positioned BETWEEN the e-brake and 4WD levers in the dash.
BUT, you mentioned removal of the 4WD actuation apparatus, so I'll also mention that when looking in there with my flashlight, saw the only thing that causes the front drive to actuate when I pull the dash lever for the 4-LOW, and that's a small pin that OUGHT to be removeable. If I could remove the pin, I'd have 2-wheel low!!
Maybe I'll post that in another thread...
