71 half doors on a 75, wiil they fit ?? (1 Viewer)
Austin,TX
I'm thinking of getting a set of half doors from a 71 to use on my 75 (with the soft top), but was wondering if I will have to modify them very much.. or if they will even fit ...
Still learning.....
erie pa
they will bolt on but you will have to use the later door latches on your truck ,and this will mean a little work and if you switch back then the latches have to be redone . if these will be on there permenatly then it is probably worth it for the extra work good luck
Austin,TX
That makes sense. I do plan on installing the H/T next winter, so I'll look into converting to the newer latches.
Thanks !!
