'71 FJ40 Hazard Flasher Location?
Federal Way, WA
Never mind. Last night I put the switch back in and now the hazards work fine. They use the same flasher as the turn signals, regardless of what the wiring schematic shows. :)
I am working my way through the wiring a bit at a time. Now that I have my turn signals, brakes, etc, working I moved on to the hazard flasher. I pull the knob and nada. So this morning I pulled out the switch, broke it open and cleaned the contacts. I'll re-install it tomorrow. Next I want to test/replace the flasher for it. Problem is I can't locate it :doh:.
So, where is that little bugger located? I bet I have looked right at it 10 times and not seen it. The turn signal flasher was in the drivers footwell and already replaced.
Steve
