700r4 and 208c crossmember
Discussion in '40- & 55-Series Tech' started by JPSFJ55, Aug 20, 2006.
  1. JPSFJ55
    JPSFJ55
    15
    Aug 18, 2006
    Kitsap County Washington
    Can anyone help with ideas or were to buy a crossmember to put a 700r4/208c into a 1972 FJ55? I have good fab skills, but no time due to work. I have no garage so I'm doing this conversion in the dirt and the rainy season is almost on me (Seattle). Any ideas to speed the process? AA doesn't have such a thing that I can find. I have access to tubing benders and such.
  2. LandCruiserPhil
    LandCruiserPhil Peter Pan Syndrome Supporting Vendor
    22,451
    Media:
    55
    Albums:
    3
    13,708
    Mar 10, 2004
    Scottsdale Arizona
    I have one in a 60 if that would help.
  3. jackbrad
    jackbrad
    668
    Mar 1, 2006
    Charlotte, NC
    What is a 208c
  4. LandCruiserPhil
    22,451
    Media:
    55
    Albums:
    3
    13,708
    Mar 10, 2004
    Scottsdale Arizona
    New process transfer case
  5. JPSFJ55
    JPSFJ55
    15
    Aug 18, 2006
    What did you use. I have a crossmemver from a 1990 Suburban I was going to widen and eventually fab a custom one from T6 aluminum. I just need to get the trans and t-case in the rig. Any help/info on the crossmember would be greatly appreciated.
  6. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    alright i don't think your just going to be able to find a cross-member for the 700r4 and np208. they use two common gm t-case mounts that look like to C's (sorta) your best bet would be to find a mount from an early suburban 86(+). the suburban that i took my 350 out of to put in my 40 had 700r4/np208 but the gearing was way to high for me.
    check out medusa's website, he has fabricated a mount for his np205 that is the exact mount you will need.
    rice's website: http://medusa.ih8mud.com/cruiser/FJ45/Frame.html
  7. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    heres hit photo's ala his website and heres the link.. he does some of the coolest fab i've seen around..
  8. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,400
    Media:
    17
    Albums:
    1
    815
    Oct 1, 2003
    MN
    There is not anything that is pre made for this application specifically that you will be able to bolt in a go....
    Time to fab something up.
    Good luck!
    -Steve
  9. JPSFJ55
    JPSFJ55
    15
    Aug 18, 2006
    Thanks for the help and sending me in the right direction. I think I'll just fab one up in place and call it good.
