- Location
- United States
I’m looking for a pair of motors for power windows in a HZJ73.
I have the regular, just need the motors.
Thanks!
Thanks!
Thanks! Partsouq was saying I may need part number 8571060040 and 8572060040 but it looks like those were discontinued.
I'm looking at these as possible alternatives but I can't find a clear photo of the stock motor connector should look like.
Left side
Right side
Left side
Right side
Thank you Matt! Do you have a LH and RH set available for purchase? If it may be a different plug that’s okay, it would be great to have the match for whatever plug is on the new motors so I can solder it in if needed.This is a japan spec. Nos window motor NipponDenso
I know it fits a host of applications…
Only difference is the correct connector plug on the end
Why not remove your current plug and swap it to a new motor like this one for example ,?
This does tail gates in 4Runners
T-100
4x4 pickup also
Look close at the bolt pattern and gear teeth
I can provide metric specs measures for you ?
No problem
Lh and rh windows alike
Matt
View attachment 3065684View attachment 3065685View attachment 3065686View attachment 3065687View attachment 3065688
Feel free to PM me details if you’d prefer.
I'll check and will get back to you. Thanks!
It's a 1996 HZJ73. Frame number is HZJ73HV-MEU
And is the motor different for 12v or 24v vehicles?
