Ok, still going over a few things however, I noticed the clamps holding my heater hoses together by the firewall were loose and water came out of them and got pretty hot while driving in the neighborhood trying to flush the radiator. Got those tightened…
I was talking to a friend who has a few LCs and works on them/rebuilds them and he mentioned that my clutch disc might not be engaging with the fly wheel after it gets heated up and that the revs on the engine might be causing the overheating at the same time. Since the truck won’t engage gear wise I’m thinking that’s very possible. All that said, I am examining the push rod play adjustment point for the clutch and height. Currently I have to let the clutch almost all the way out before it engages during the first 5-10 min of driving it before it just won’t do anything more. I’ve checked the spring and rods and all is intact and seems to be fine.
@65swb45 Mark, a different guy who helped install the booster/lines/disc brakes and axle sent me this diagram of what he did. Can you explain your opinion on what’s going on here or I can call tomorrow and go over it with you? I’d like to hear your opinion as the other day when I parked the 40, it locked up and would not roll even in neutral. I was told today that it could be the check valve potentially and that if I had pulled that to open it I would have more than likely heard air coming out and then the brake releasing? I’m still learning so my apologies for the lack of knowledge or understanding and poor explaining…
