- Location
- United States
Up for sale is a swap kit to put a Dodge 5.9 liter 12-valve 6BT diesel and manual NV4500 4WD 5-speed transmission into a 1993 FZJ80. The installer will need to source the engine, transmission, and alternator (Delco Remy 28SI). This is as close to a turn-key kit as you will find.
I am asking $2,000 + shipping for the whole kit. Not willing to separate. PayPal only. PayPal address must match shipping address.
This is a repost from Will who posted this kit which I purchased and never got around to getting off the ground. I've decided to rebuild my 1FZE instead of installing a 6bt/NV4500 as a replacement. I also never aqcuired the machined NV4500 shaft from him in the process, but overall this kit would allow mostly bolt in setup.
The kit includes:
Pics to follow
The kit includes:
- Engine Mounts
- Transmission Mount to work with OEM crossmember
- Trans/T-case Adapter plate between NV4500 and HF2AV
- Throttle Bracket
- Transfer Case Shifter Bracket
- Spud shaft or machined NV4500 output shaft to adapt NV4500 output to Toyota t-case input
- Wiring Harness w/ diesel tach adapter (1993)
- Power Steering Hose
- SSOR Accessory Bracket for conventional A/C compressor and Alternator
- SSOR machined coolant outlet pipe
- A/C Adapter fittings for use with factory A/C condenser and firewall hardline
- Sanden heavy duty A/C Compressor
- Full Toyota OEM manual trans pedal assembly including buckets and hardware
- "Killer Dowel Pin" kit for 6BT timing gear
- LarryB's Heavy Duty Fuel Shutoff Solenoid Kit
- Miscellaneous seals, gaskets, and adapter fittings to complete the swap
Pics to follow
