68 clutch master cylinder
guadalajara, mexico
Website
www.instagram.com
hi
I have a problem to put apart the cap of the old clutch master cykinder, it seams that is rust weld, an i try so many things
any sugestions????
plaese! jejeje
I had the same problem with mine (1970) I just purchased a rebuild kit locally and honed the cylinder installed it and have had no problems.
The plug will thread out, it's probably just rusted. Use a good penetrating oil (3M penetrant works well) and, as the book shows, put it in a vise, and use a pipe wrench. I just finished the same job, both master and slave, and it was no fun. It took 3 hours to break the end plug loose. The end plug is about 3/4 inch deep fine thread, Just use the penetrant and go easy. You'll get it. Pictures below. Good Luck
For reference, you can get a brand-new OEM Aisin master from Specter for $160 or a new aftermarket for $70.
sence I'am in mexico , I went there last week, and I bougt the replasment kit , but I realice ,that i had the earlier version put in to.
so I'm tryn to fix the old one I have , and see whats append
now it are on the penetrant oil stage!!
best and wish me look!!!!
ok at last somebody make it in 15 minutes
put it on a table screw holder and give some hits wiht a hammer on the sides , then usind the pipe wrench, just some arm power and WHALA!, is out , I clean it and put it togeder and that's it
TX !!
