67' drive shaft to a 76' axle
Change the pinion flange to your old one, or swap out the front half of a later model 4-speed driveshaft with your 3-speed back half. I changed out the pinion flange on mine. The old pinion nut was castle/cotterpin and the newer nut was staked...so I used the new nut and the old flange.
Clear as MUD?
HTH
Ed
You are right on Mike..
Swap the flange...
RED LOCKTITE AND STAKE THE NUT AFTER IT IS TOURQUED!
(been done many, many times)
Good luck!
-Steve
nuclearlemon said:
early model had smaller bolts than the 70's models. easiest way is to swap in whatever slipshaft mates to the pinion flange.
Because changing out the flange on the diff is so hard???
Should both be coarse spline, unless someone has jacked with things...
yes it's too hard...besides...you saw my fingers after dealing with pinion flanges :flipoff2:
Too hard?
DO IT RIGHT!!!!
and forgive me, I do not remember your fingers after dealing with pinion flanges...only you showing off a lovely fushia nail shade... ;)
-Steve
I think fushia has a "c" in it somewhere. He, he.
Ed
I do not have my old axle. I looked in SOR catalog and they changed bolt sizes in 68'. Just to be sure that I get the right part, I need a 67 or older axle to pull the pinion flange from? Should I replace the pinion oil seal? How many pounds does it need to be tourqued too? Thanks Al
Poser said:
Too hard?
DO IT RIGHT!!!!
-Steve
what could be wrong...by going with the 76 slip shaft and pinion flange, you are upgrading to a larger bolt. best idea would be to swap out the xfer output flange to later model and change complete driveshaft to 76 with the larger bolts, but since existing shaft is already modified, i can see not being able to do that right away.
Are the U-joints the same size? If so can't you just swap the flange on the driveshaft, leaving everything else alone? If so when I get my H55 flange from cruiserparts I will have one available.
I think I will take my snow shovel to the bone yard this weekend, and see if I can pull the pinion flange from one of the cruisers there. Cheers to all for options and advice. If I cannot find the correct one I will be in touch. Al
