- Location
- United States
'65 LWB Project for sale.
The last of my personal project vehicles, originally purchased from Whitey 10(?) years ago.
This '65 FJ45 is set-up with a strong 1HD-T, H55/Split Case Combo. The engine has 122 Kilometers on it, and sits in front of a NEW (zero miles) H55. Connecting the 2 with a NEW Bell housing, Terrain Tamer HD Pressure Plate and Clutch Disc as well as a NEW 300mm Toyota FlyWheel. The Split Case has been serviced with a seal/bearing/gasket kit. The Front End has been rebuilt with an FJ62 Knuckle out set-up and a Toyota Long Splined Inner Axle(70 Series) to support the 80 Series Electric Lockers. The Rear End is a 70 Series Full Float that was NEW from Toyota 10+ years ago with 0 miles on it. It is a Disc Brake Axle with a Long Spline to support the 80 Series electric Locker also. 5 16" Tires/Rims compliment the OEM 2 1/2" suspension. All the shackles and U-Bolts are NEW.
The Frame was stripped, and put on a rack to achieve 100% perfect straightness before boxing in the rear frame channels(major weakness in LWB frame). I also added my personal style FJ60 Power Steering Box set-up to allow for an effortless large Tie Rod (70 series) and Relay Rod (70 series) install. All Ends fit perfectly with the FJ62 Knuckle out conversion without additional parts.
The Bed and TailGate are NEW repros from Kevin, aka Awl_TEQ. TailGate Chains, Latches are all NEW. Front SheetMetal is in Excellent shape. All the Lights are either NEW or restored(cab light and tail lights). Included is NEW Rubber from Toyota. All switches have been tested, hopefully the photos will reveal their conditions. Photos should also speak for any/all hard to find items included with the sale. Tool kit, Jack, Manuals and Service Books are all included.
The wiring Harness is 90%. I unwrapped it to duplicate for a SWB Restoration. I have included lengths and colors per CoolerMan's wiring replacements.
68 PHOTOS v
$16K
68 PHOTOS v
$16K
