65' fj-40 rear disc brakes?
Discussion in '40- & 55-Series Tech' started by guenther65, Mar 11, 2004.
  1. guenther65
    guenther65
    124
    Apr 23, 2003
    I HAVE A 65' FJ-40 THAT IS NOW RECEIVING A FRONT DISC CONVERSION. I WAS WONDERING IF IT IS WORTH THE MONEY TO CONVERT THE REAR. THE GUY I HAVE DOING IT SAYS IT IS NOT WORTH THE EXPENSE. WHAT DO YOU ALL THINK? :-\
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    Do it now, and be done with it.
    Been covered very extensivly out here in the past couple months..
    Are you using a power brake unit, are you swapping a whole axle assembly, and what master are you going to use?
    Good luck!
    -Steve
  3. Hodag
    Hodag Guest
    My suggestion is just do it. I did mine while I had my axles out while putting in my locker. Once you gather up the parts (go to the tech links here for the lists), it took less than 15 min per side. Bleed em and go. I did not use a porportioning valve, but I still may in the future. The rears will lock up much faster than the fronts in a panic stop. Mine is a 78 so I didnt have to change the master and booster, but if youre converting your front too, youve probably already changed yours. Thats my $.02, Hodag :D
  4. guenther65
    guenther65
    124
    Apr 23, 2003
    My guy is pulling out the old front end and replacing it with a later model disc front end. It will have a new booster, master and porportioning valve. I was thinking about going to a full floater in the rear. I want to use only landcruiser parts for the rear brakes. What about the park brake?
