62 Champaign Paint Whats Close? (1 Viewer)
North Front Range, CO
What is the closest paint in a spray can the most matches Champaign?
I don't need a real match so close will do.
Some paint stores will scan a sample and make a match for you. You can use your gas door for a sample.
Look at the drives door, the exterior paint code should be there. If you have a good automotive paint store nearby they may be able to mix it for you put it in a spray can. If not a small airbrush will work wonders and don't cost much.
I don't need matched paint as I just fill some rust holes with GreatStuff expanding foam (to keep the water out) and want to paint the foam.
Any paint from hardware store will work if its close.
