Ok...
Its been a week or so trying to fix this bugger.
The pulley came off while coming home from holidays. The key was lost and the keyway badly damaged.
Go here for a bigger image
It is an old car worth $3 or 4 K so I have tried to use devcon to repair the keyway rather than a whole crankshaft fix. The first devcon repair didn't hold. I discovered it had failed when I had to pull the whole lot off to replace the timing cover gasket.
Today I re-devconed it but I have very little faith that it will work.
I am wondering if I can weld the key in place, grind it back sufficinetly and then slot the balancer over the whole lot?
Anyone done this successfully?
Another thought is to drill two holes in the crank and slot in 2 high tensile 'dowels' to use as keys.
Right now I am open to all suggestions as pulling the motor out and repairing the crank is not looking like a possibility.
Any thoughts?
( I have read this thread https://forum.ih8mud.com/showthread.php?t=28866&highlight=crankshaft)
Any thoughts?
