I'm sure someone has already done this but I though I would post it for anyone that may be searching for a fix.
Problem: Rear seat belts will not pull out/ are locked unless you manually feed them back in. It's like the springs wont pull them back in far enough for the ratchet to let go.
I have to get out and help the kids about half the time.
Cheap fix:
I removed the seat belt assm from behind the seat. Had to lift the my rubber liner. 1 big bolt.
The black plastic cover just folds back to reveal the spool.
The spring loaded metal piece on the right above controls the ratchet mechanism.
When the spool gets big, it releases the lock because the belt is in.
Since my belt wont go in all the way, I added a little offset.
This makes it release a little earlier than usual. It still locks when it is out far enough to go around someone.
I used a cable tie. See pic. Something else may work better.
If you use a cable tie, be sure to tuck it like the pic. Otherwise it will hit the black cover and bind everything making it worse.
Sems to work.
I imagine it will wear out eventually.
DW
Cheap fix:
Sems to work.
DW
