afraptor22
- Location
- United States
I’m going to go 1-tons on my 45 and need to sell my current axles, transfer case, doubler and wheels! This is for the axles but I have other ad’s for the BlackBox Doubler and split case and Sumo underdrive gears and 35” tires and wheels.
Front axle $2500
60 series housing
60 knuckles cut and turned for spring over
Full Redline big brake kit (needs 17” wheels)
IFS hubs part of Redline kit makes these slip on rotors and 3” wider so it matches 80 rear
Marlin 25mm pins trunions and high steer
Toyota LSD carrier
4.56 gears
Marlin chromo shafts and birfields
Marlin inner seals
Marlin weld on knuckle braces
2 sets of locking hubs
Spare axle shafts, some seals, spare hub and bearings
Will come with tie rod and 80 series TREs, no drag link
Rear Axle $1500
ARB carrier with hose, no compressor or switches….maybe for extra if I don’t use air again
4.56 gears
Nitro chromo shafts
Spare stock shafts
Spring perches welded on for custom width so assume they will NOT work for you
HD shock mounts
Spare brake pads and seals
Pics I have were not intended to “showcase” the axles so I’ll grab better ones this weekend. Axles are on the truck but I’ll be starting to pull them this weekend. I do have a set of roller 35s that can be on them for a little $.
Front axle $2500
60 series housing
Toyota LSD carrier
4.56 gears
Marlin inner seals
Rear Axle $1500
4.56 gears
Nitro chromo shafts
Spare stock shafts
HD shock mounts
