60 Engine Parts Plus... (1 Viewer)
Larkspur, CO
1983 FJ60 Engine Parts Plus...
AS OF 03/29/09: NO REASONABLE OFFER REFUSED! IT GOES BY 03/31 OR I'M THROWING IT IN THE DUMPSTER!
From my '83 60 (when it got the 2F from my '84):
Aisin carb $150 SOLD
Carb fan $30
Throttle linkage $10 SOLD
Gas pedal cover $2 (free with $20 other parts)
A/C Compressor $50
A/C high pressure line $10
Air cleaner box $30 ($20 with K&N & recharge kit)
K&N air filter & recharge kit $20
Motor mount $10
Air injection rail $20
EGR cooler $30
Clutch pedal & pad $15
Various emissions control devices $15 each
Engine controller $20
Taiwanese repro 62 mirrors with REAL glass & gaskets $20 SOLD
Fan shroud $20
NEW 01/26/09 PIX 2 & 3
Misc heat shields $5 ea
Good 4-speed $50
DS yoke with U-joints $10
Almost brand-new carb isolator $25 SOLD
AC mount bracket & adjuster $30
Motor mounts $10 ea
Alt adjuster $15 PENDING
Cat temp sensor $10
Choke knob (missing in pic) & cable, everything works $15
MAF fluid heat riser (minus gasket) $30
Rear spring shackle pins & bushings, NIBs, $30 for the whole mess
(12) 90389-18002 SPRING BUSH HALVES - $2 EA
(2) 04482-60040 PIN KIT, RR SPRING INCL 2 BUSH HALVES - $8 EA
(3) 94512-01200 WASHER, SPRING - $0.25 EA
(1) 90119-12032 BOLT, WASHER - $1
(2) 91611-61040 BOLT, WASHER - $1 EA
(1) SOR 243-33 TOW HOOK CLIP - $1.50
Plus a couple other things in the pix I forgot or mis-identified.
Plus crating on big stuff & shipping on everything (FedEx ground on big, USPS Priority Mail otherwise)
Best to email me: steve@restocustoms.com
Throttle linkage, gas pedal cover, A/C high pressure line, air cleaner box, motor mount, air injection rail, oil cooler, clutch pedal & pad, various emissions control devices, engine controller, professionally rebuilt Aisin carb, A/C compressor, low pressure A/C pipe/hose, Taiwanese repro 62 mirrors with REAL glass & gaskets, fan shroud, K&N air filter, & a couple other things in the pic I forgot or mis-identified.
Best to email me: steve@satelliteglass.com
consider the carb sold
Click on the Part Number to order or view price.
In your parts picture do have number 7, That is to the left of the number 50 the first 7
'83 FJ60.
I'm housecleaning & don't know what this stuff goes for. If you're interested in something, make me an offer, but don't make it ridiculous. I can take detailed pix on Monday 01/12/09 if necessary.
Again, best to email me steve@satelliteglass.com.
Siren -
If you search you'll find a thread where I described the mirrors: I replaced the glass with Burco FJ62 replacements so it wasn't wavy any more, but they vibrate. Better than broken stock 60 mirrors, though.
Jmk -
I think that's it above the mirror to the right: it has a black knob about 1/2" in diameter & about 3/4" long attached by a 1/4" shaft to a valve that has 2 long hoses I coiled up. If you identify it by name I'll look in my emissions control book. The stuff is at my shop however & I won't have it in my hand to 100% identify until Monday.
Szester got the carb: CaliCruiser is interested in the A/C compressor.
CaliCruiser bowed out on the A/C compressor so it's back on the list: $50
PM and email sent on the alternator adjuster and carb riser/insulator. Thanks. David
i really would like the tranny but shipping will kill me...73127? (business) Could you humor me?
Cali -
Sorry, haven't looked at this in a while: the stuff in bags is NIB. Tell me what you want & I'll get you the part #s
Aggie -
You need a vacation: Colorado's calling! It's 2 min off I-25.
Again, best to email me: steve@restocustoms.com
I will take the oil cooler although I don't see it in the pictures. Email sent.
Are the motor mounts for the early 60 the same as the late 60? If so then I'll take the one that's in best condition.
