For Sale 60/62: alt ps p, knuckle to hub assy, wp, bat try, air p, cond, soa perchs, strtr, relays and more (1 Viewer)
North of LA California
If you don’t see it ask. I have a bunch of spare 60/62 parts I’m clearing out. Prices are negot
Pass knuckle, spindle, and hub.
battery tray and all acc for a dual batt setup
water pump
62 condenser
62 air smog pump
62 coil pack
62 alternator ( I have 2)
62 distrubi
62 exhaust heat shields
starter (&2 more for parts)
upper/lower t stat housing and all sensors in place
62 dash - tac Speedo gauges etc
random assortment of relays
random knuckle rebuild hardware for those missing pieces.
ruffstuff front SOA perches
marlin knuckle gussets & shock mounts
Oem center wheel caps, 2
Not shown in pics:
A440F and trade still mated together
A440F of unknown condition. Was told it was good.
3FE block and head. Needs full rebuild.
Entire set of 3FE parts to make a 2FE for the 60crowd.
62 brass radiator
rear 62 driveshaft
62 rear axle shafts (2 sets)
set it knuckles matched to 4runner calipers
two rear semi float 62 housings cheap!
62 rear heater hard lines for you East Coast rust belters.
custom 62 trans hoses and trans cooler to save your A440F from over hearing.
3FE alternator engine mount bracket modified to run 80 series alternators
Huge Leece Neville Alternator.
FJ40 / mini truck butchered Confer roll bar: free to a good time
60 and 62 door cards. Ok condition.
rear 62 speaker grill.
assorted springs
Georg,
I’ll trade you my stash for 4:1 tcase gears :p
@orangefj45
Shoot me a pm Xavier. I need to know if you want just the battery tray and mount or the coolant overflow mount.
Also, do you want the cooler alone or the custom made lines ready to hook the A440F to the cooler.
Cheers.
Cooler and hose
