#6 White to brown bodywork and paint (Tatonka) (4 Viewers)
kelly saad
Supporting Vendor
Flagstaff Arizona
Drivers side. Let’s see how this goes.
kelly saad
Supporting Vendor
Flagstaff Arizona
This is what I was able to accomplish. The body lines look straight, the panel correct without any wavy areas or low/high spots. This is the tricky part, to get the steel the right shape, so that the filler is minimal thickness. I use pry bars and 2x4's from the backside, pushing outward until it looks right, then tack it. I do this every 5 or so inches until the outer curvature and shape is extremely close. Also, these quarters were damaged in a collision previously, and had filler covering much of the back halves. They did a good job straightening out the metal though, but it's still not perfect. I will work on it a little more before filler. It should be another fun one!
