5speed frm 2h/2f motor
You'll have to change the input shaft which will essentially equal a tranny rebuild.
He is correct. The F series gassers and H series diesels share the same transmission input shaft. The B series uses a longer transmission input shaft. Normally it is the other way around. Folks find an H55 from a B series and want to use it with their F series gasser. In their case the transmission input shaft would be to long.
