5spd into my 1974 fj40.....what mods needed??
I have a 1974 Fj40 with a three speed, and am looking to swap it out with a h55f tranny I bought from Australia. What mods need to be done? Can I use the 3spd transfer case? Is this a tough swap?
Thanks for the info :D
1994 FZJ80 1990 FJ62 1974 FJ40
Quick reply:
You need...
Split style t-case
4 speed Bellhousing/clutch
Driveline mods (both lenth and flanges)
Tranny hump mods
Trans crossmember
Hey In2,
I too think this is a cool idea. Spendy, but cool. How much did it cost you to get a Aussie H55F into your hands (if you don't mind me asking)?
There are some cool posts on this topic, both here and on Pirate (pirate4x4.com - TLC section). Just run a search for H55F...
I believe you need a t-case that is mid 85, 86 or 97 to work (I think it is the 38 mm idler case?)
Seems like the trickiest thing to figure is your e-brake. Some people don't give a $hit, some people run line-locks and then there are those folks who want to go to TLCA sanctioned events, where part of the tech inspection is a functioning e-brake that isn't a line lock.
Check this out also:
http://www.off-road.com/tlc/tech/h55fswap/
Good luck mate!
I just finished this on my project. H55F to split case from a 1986. TC received Mark's gears too. I had to removed the crossmember. It's replacement is fitted but not welded in yet. I was told about the floor mods, but was also told a body lift would solve this problem. I haven't set the body down yet to know how much of mod it's going to take. I did the TC mounted ebrake conversion. I bought the kit from Liquid Off-Road, but if I did it over again I would purchase the Spector kit. It cost more, but I think it's more complete.
PabloCruise said:
Pappy,
You went w/ CV joints front and rear?
Can you tell us more about your lift?
Spring over axle. Alcan springs front and rear. Rear 2" longer than stock using stock fixed mount and cutting off and moving rear shackle mount. Front has shackle reversal using Proffitt's spring hangers and shackle bushing sleeves. Front springs are two inches longer than stock (maybe three, I don't remember). Front SO axle also from Profitts. Front axle moved forward two inches, rear moved back two inches.
The only thing I would do different is not have Proffitts weld on the spring perches. I had to cut them off to rotate the pinion up more.
Those are early FJ60 driveshafts. The rear shaft is only 22" long. The front was probably long enough to not go CV, but I pointed up the pinion so it was needed.
