55s steering collum ,Why are these wanted
Discussion in '40- & 55-Series Tech' started by 4BGaz, Jul 10, 2005.
  1. 4BGaz
    4BGaz
    29
    Jul 25, 2004
    Sydney
    why are the 55s steering collum a wanted iteam for 45s,just got a 55s for wrecking
  2. bad_religion_au
    bad_religion_au
    2,213
    2
    Apr 24, 2003
    they have a slip joint on the steering shaft, so that they are easily mated to a power steering box, where as the 40 and 45 colums are solid mounted to the box
  3. Mark W
    Mark W
    6,232
    282
    Jan 7, 2005
    The Greatland
    Actually only the early '40s are solidly connected to the box. But the later '40s have a rag joint, the flange of which is integral to the shaft. The '55 ends in a splined section for mating to the Toyota ujoint/intermediate shaft. It also has a bearing in the bottom end of the column (to locate and support the shaft). The '40 column does not have this and depends connection at the rag joint to locate the bottom end of the shaft.
    Sooo... for doing PS conversions, combining the '55 column with a '40 column results in a hybrid which bolts right in and is the perfect unit when adding an intermediate shaft.
    Mark...
  4. nuclearlemon
    nuclearlemon not an addict Moderator
    16,256
    Media:
    87
    Albums:
    4
    1,112
    Jan 30, 2003
    meh-ico, colorado
    the rag joint vs. u joints isn't the only big thing about the shafts...it's the fact that the 55 has a slip shaft
  5. mr_manny
    mr_manny
    1,655
    13
    Apr 10, 2004
    san pancho, ca
    Other then using parts from a 55 column, is there another way to modify a 40 for MT upgrade?
    thanks,
    manny
  6. Mark W
    Mark W
    6,232
    282
    Jan 7, 2005
    The Greatland
    Right. The use of the intermediate shaft (which can be lenghtened to work with a variety of setups) and of course the bearing in the end of the column is what make this a "good thing".
    Mark...
  7. Mark W
    Mark W
    6,232
    282
    Jan 7, 2005
    The Greatland
    I guess I'm drawing a blank here... "MT upgrade"?
    Mark...
  8. nuclearlemon
    16,256
    Media:
    87
    Albums:
    4
    1,112
    Jan 30, 2003
    meh-ico, colorado
    do you think he meant ps instead of mt.
  9. Texican
    Texican s-Moderator
    5,964
    Media:
    175
    Albums:
    7
    321
    Dec 17, 2002
    Bonham Tx.
    I know it's no consolation, but, me too.... :confused:
    Butch
  10. Pighead
    Pighead Stop calling it an FJ
    7,592
    647
    Aug 31, 2004
    Denverish
    Mini Truck?
  11. krzyabncanuck
    krzyabncanuck USFS HOTSHOT GOLD Star
    8,717
    735
    Apr 5, 2005
    NC
    Mini truck power steering ?
  12. CruisinGA
    CruisinGA
    6,169
    16
    Mar 27, 2003
    Georgia Tech
    to answer the question, yes.
    You can bolt a pillow block bearing on the firewall side of the steering column to axially locate the shaft.
  13. incogrhino
    incogrhino
    669
    53
    Feb 29, 2004
    ravenna Mi sittin 10 deep.
    I just built mine last week.The 55 colunm is like a inch and a half longer.I just took it to da chop saw and nipped it.Get one, it's easy.I had to swap turn signal switches so it would plug into my harness.That and I like my steering wheel better.
  14. mr_manny
    mr_manny
    1,655
    13
    Apr 10, 2004
    san pancho, ca
    sorry guys, MT = Toyota Mini Truck PS upgrade...
    I understand we have a cruiser on this forum that sells brackets that accommodate a MT gearbox for fj40s.
    thanks for the info,
    manny
  15. Mark W
    Mark W
    6,232
    282
    Jan 7, 2005
    The Greatland
    In that case there are no needs for any change. The minitruck box is a bolt in with the replacement pedestal. No need to change the column or naything else.
    Mark...
  16. Rocky_LC
    Rocky_LC
    1,568
    52
    Sep 16, 2002
    Tucson, AZ
    Replacement bearing part numbers for FJ-55 Shaft:
    Top:
    NOTE: THis is some kind of wacky hybrid bearing, with an 18.5 ID. The two bearing houses did not recognize the other part numbers, and told me I had to source this from Toyota.
    Toyota: 90363-18038
    Koyo: DG1938AC3
    NSK: B18Z-1B1C3
    Bottom:
    No problem with this bearing - I got the 6004ZZC3 bearing.
    Toyota: 97123-06004
    Koyo: 6004ZZC3
    NSK: 6004ZZC3
    Russian Bearing Cross Reference Spreadsheet... Search on OEM P/N
    http://www.avalux-motors.ru/files/K...ikov_i_podshipnikov_v_originalnye_nomera_.xls
    Rocky
