55 road trip to all 50 states
Another few hundred miles today, went out to Pueblo Mountain to propeller meadows in south east Oregon. Last bit of the road was a bit slick and muddy. Other two rigs couldn’t make the last bit so we piled 10 people into the 55 to get the last bit of road done
Took a bit but we made slc for cruiser fest tomorrow. Right rear axle is a bit warm, and we had acouple times of getting warmer than I wanted. I know I wanted to replace the radiator but it’s been good so far tell sitting in slow traffic in the heat. Little urban camping for the night in a koa, then will split the drive home into two days for something to do.
Please post some photos from the event. I was considering flying down for the day but the flight out of JNU filled up for standby. And, the weather is unusually nice here.
I’m more for the rigs in the parking lot being driven than the ones in the museum but it is fun to see some of the early rigs. Was a good day to be the only 55. now to start the drive home and find a place to camp for the night...
My interest would also be greater for the parking lot vehicles. Many 70 series? It's somewhat surprising you were the only 55. I guess that means you will need to return regularly. :)
Long weekend driving turns into long week of kitchen remodeling. Started pulling cabinets at 6am had them installed in a different rental by 11 am. Then back to rip out walls. Still working at moving plumbing and adding outlets tonight then new Sheetrock and cabinets tomorrow is the hope. Then floor removal and patch and sand and and and
No insulation in that old house?
Zilch. 1930 Edward Hines Mill house. Has some blown in the attic, will put a little r13 in those few bays because I have it and it’s open. Thought about doing blown in all along that wall but what good does that really get me vs the cost, when the second floor above it wouldn’t have any and none of the other walls would have it. And I’m not drilling holes in each cavity they lathe and plaster just to add insulation in the whole house. It’s been ok for the last 100 years so should be ok for me.
You were the only 55?!?
Yeah only pig there. She did good on the trip. Steering box was leaking on the way home so will get that pulled and rebuilt. Got a new radiator coming as this one has been on its last leg for awhile with crusty old fins and a leak but still got an extra 20k miles out of it. New brake pads up front after the trip and it will be ready for another 10k miles or so
Down the rabbit hole we go. New brake pads turns into having rotors turned, rebuild calipers as they are not working smoothly and more pressure on the bottom piston than top piston so rebuild that. Then steering is leaking so pull and rebuild 60 box. And replace the garbage u joints from Napa that lasted about 1000 miles before horrible vibrations. So new matsui u joints. Then get this all together and then swap radiator when the new shows up.
Getting it ready for a 3000 mile round trip down thru baja in acouple months. Little by little fix and drive. Then start over on whatever the first project was over time.
And the kitchen remodel is slowly moving forward ontop of cruiser work and work work. Walls removed electrical moved and rewired. New cabinets are partially in. No doors just the cabinets and counters are in. New oak floors are in.
