On the maintenance side of things, we're getting through the old checklist. Husband has been diligently working to finish up some of the smaller maintenance items. He changed the spark plugs, O2 sensors, charcoal canister, and got started on a Big 3-style ground upgrade. The spark plugs were in for almost 3500 miles and had some buildup on them. Could be worn valve seals, piston rings, or accumulated gunk from when we first got it running. The previously failed FPR probably didn't help either. We'll see how these new Denso plugs look with a few miles on them.
The O2 sensors came out easily enough: one was missing hardware. And after seeing how the mounting studs were stripped, it's easy to see why. We'll see if our friend at the shop can help with that. That's currently causing a small exhaust leak.
The charcoal canister seems to be helping as well. Husband noticed some slight pressure buildup in the tank at gas stations this past summer. So we're hoping this helps to prevent that.
On the interior side of things, I got an email from my wishlist on Partsouq saying the driver side window switch bezel was back in stock. So I jumped on that and a new cigarette lighter assembly. Our current bezel has broken tabs and is supported with a strip of ducktape underneath - it mostly works, but is not ideal for the long run. The cigarette lighter port in the car also mostly works, but frequently cuts power while driving. Super annoying to hear the dashcam or Bose speaker chime from powering on repeatedly. Not to mention it's probably a fire hazard.
Once we get through this list, we'll start focusing on more "quality of life" interior repairs: air vents, floor mats, stereo, seats, etc.
Install new charcoal canister
Get spare tire mounted
Install passenger visor
Front brake pads & rotors
Engine & transmission mounts - may not need after all
New front & rear u-joints and hardware - lubricated & work great
Service front axle
Extend diff breathers
Install rear OME springs
Replace fuel pump
Fix power steering leak
Fix exhaust
Remove factory roof rack
Reinstall roof bars & tent
Install charcoal canister
Install spare tire level kit
Change OEM spark plugs
Change oil
Replace O2 sensors
"Big 3" style wiring upgrade
Replace DS window switch bezel
Replace cigarette lighter port
Replace brake light switch
Replace shift lock computer? - may need to test reverse lights
As for the fun side of things:
The weather this past weekend was ideal, so we went out to a friend's future homesite. He's been clearing the drive and needed to burn the debris. Good excuse to camp.
