5 speed trans and rear axle
Status
Not open for further replies.
Knee deep in hookers and gin
richmond doug nash 5 speed - 32 spline gm output. chevy bellhousing. clutch and p-plate. currently adapted to a np208 transfer with the 6 bolt round gm pattern. shifter linkage included.
ratios - 3.27 2.14 1.57 1.23 1.00 not an overdrive
500.00
toyota t-100 rear axle. from an 93 with the 3.0l and auto if that makes a difference.
full width centered rear toyota axle
100.00
gm hydroboost system - booster, master, pump and lines - 100.00
2 4 speed toyota transmissions 20.00 no ship
sm465 - 32 spline long output - free no ship
half dozen hard top sides of various vintages. free no ship. don't even ask.
couple sets of soft top doors. free. no ship. i will make fun of you publically if you ask me to ship them.
i need 79-up knuckles, high steer arms, lunchbox lockers and 35-39 tires
PO of the trans adapted it to fit in his 84 K-10.
Found the Downey "low profile" super secret p-plate that I bought for my 6.2L conversion. Less than 100 miles on it. $75 paid $275
Edlebrock square bore carb. Works great on road. Manual choke. Don't have the numbers here, but if you're interested, I can get 'em. With some work, I understand they can be made to work off-road. I just swapped it out for a quadrajet. $40
Got the 6.2L flywheel I bought for the conversion as well. Monsterly heavy and balanced for the 6.2. Not good for much else. Shipping would cost more than the part is worth. $20
Got two clutches the bastid went through before I grew a brain and put a TH400 in it. Both have low miles and blown out centers. :doh:
FJ-55 radiator. No idea what they are worth
Got the whole serp belt system for the hydro-boost. Comes with a A/C compressor, alternator and adjuster pulley. Coulda swore somebody was after a hydroboost.
Status
