Ok, so i am about to make an offer on an h55f with a split transfer case/fairey overdrive unit and i want to fit this to a late fj55 with a 4 spd and pre-split transfer case.
I want to know:
- Will the 4 speed bellhousing (2f) fit to the 5 speed gearbox.
- Will/can the gears be swapped in the transfer from the 19 spline to the 16 spline shaft if the the bellhousing doesn't fit?
- Can i use the original transmission mounting system or do i need to make a cross member?
Any help would be greatly appreciated.
Best regards,
Dave.
I want to know:
Best regards,
Dave.
