5,9 cummins
Iceland
Website
www.instagram.com
Hi.
Is a 5.9 cummins in a pig a viable option? Weight and power vise.
the main reason I ask is because I really want a diesel in my fj55 but the big toyota disels cost an arm and a leg over here and I don´t think there is a single 3.9 cummins over here, but 5.9s are abundant :)
so, am I crazy to think it will work on a 55 drivetrain?:grinpimp:
Talos said:
Hi.
What is your primary use going to be?
I would run a 12 valve non intercooled cummins with a NV4500, split case, and stock (30 spline'd) axles if I knew that it would never see a heavy right foot or large tires. That engine is pretty damn heavy, and makes great low end. Once you step up to upgraded axles you might be a little safer.
Beyond that, I would definately beef up the drivetrain, just in case.
I've often thought of a ISB powered 55 pick up, with eaton front and rear axles and a hell of a hitch. Bomber.
Good luck! :beer:
EDIT:
Wait a minute- I take everything back (memory laspe made me forget what 44" tired 55 belonged to whom). WHEN (since you shouldn't not do it) you go with a Cummins 5.9L, you should go with a 1-ton drive line. Complete from flywheel to all 32 lug nuts. Between deep snow, 44" tires, and a 5.9L, I wouldn't want to spend any more time than I had to fixing broken parts out on the middle of a glacier. :)
if you search on pirate there is someone who has done this. i think he had some problems with the length and radiator/ fan fitment. he was very happy with it's performance last time i checked.
HTH, carl
I know I was being a tad optimistic :) just wanted to know if anyone had done it.
by the way what´s a good 4bt going for? and what´s the best place to get a good one?
has anyone bought from these guys? http://www.arsco.com/cummins.htm
Great lead on rebuilt 4bt cummins
These 4btcummins are rebuilt here in Denver, Colorado.
This is a Quote from another website.
(My name is Russ, and I live here in Colorado. I have engines available for sale. They are Cummins 4bts, automotive applications. 105 hp. They are total rebuilts, and I stand by them!!! The engines are going for 2200.00 with no core charge. If interested, you can e-mail me, or contact via phone 303-564-6545. Thanks.)
That price is decent. But, those of you looking for 4BT's, his motors may not come with the flywheel or the ring adaptor to mate to GM trannies.
Flywheel: $750 from Cummins
Ring adaptor: $650 from Cummins.
Having a Cummins powered Cruiser: priceless.
Just thought I would give a head's up on some of the hidden costs.
FWIW, Proffitts Cruisers has 2 4BT's left for sale.
Call 1-877-PROFFITT for info.
