I just acquired a 62 with the vortec in it. Great truck but a few minor items to be ironed out. the first thing I need to address is the pedal set up. The brake pedal and accelerator are too close together. It doesn't help that the brake pedal has about 3/4 of an inch of lateral play in it also. I keep catching the gas pedal with the side of my foot when going for the brake. Unprompted my friend did it also on first drive.
The pedal is 3/4 of an inch to 1 and a half inches away from the gas depending on the play issue.
A lot of the pedal issues I read about in the 5.3 conversion threads are more about issues with the skinny pedal rather than the brake. Has anyone had this particular issue? I am told it is a stock GM pedal set up.
Although it is very hard to see I wonder if the diameter of the bolt holding the pedal in place is too narrow causing the sideways play?
Anyone have an 05 Yukon or Tahoe? What is the usual space between pedals? Is the stock GM set up usually so close?
Any help greatly appreciated
