There are several threads regarding the 5.3 swap and I think I've read them all, but I have a few other questions.
My 73 FJ is currently setup and has been running with a 350 SBC connected to a SM465 4-speed, an adapter plate and the Factory Toyota Txfer case, making a stock driveline length - I'd like to keep it like that. It also has an FJ60 rear axle assembly with (front & rear 3.73 diff) and fine-spline axles).
Project: 5.3 - SM465
I have a low-mileage (2002) 5.3L Vortec out of a pickup truck.
2002 and older trucks use a throttle cable for the accelerator pedal and not the fly-by-wire.
I want to mate the 5.3 up to the SM465 and was told by reliable sources that all bolt holes between the bellhousing and engine block line up perfectly with the exception of (ONLY) 2 holes that need to be drilled and tapped...And some people are actually running their rig without these extra bolts (not my plan...but it will confirm the rumor if true).
My questions:
1.) Does the SM465 bellhousing bolt up to the 5.3 block ?
2.) Will the existing SBC Motor Mounts bolt up to the 5.3 with an adapter plate (which I already have) or is the location on the frame different ?
3.) Will the stock 5.3 exhaust manifolds clear the frame rail ?
Will they just be tight or is it mandatory to install headers ?
4.) Wiring Harness - When removing the wiring Harness and computer from the donor vehicle, are there any wires that pass thru the firewall into the cab of the truck that are (MANDATORY) or are they just an added bonus- for example---check engine light, and ECM connector to check codes, etc... ?
--> If the harness is cut at the firewall (but 100% complete under the hood) will that be sufficient to start the engine ?
5.) Will an off-the-shelf (high performance) electric fuel pump be enough to supply the injectors or will I need something special ?
I'll be sure to document the swap with photos and notes...
Thanks for any info
My questions:
Thanks for any info
