Cant wait to get one for my LX.
Rwhat: Any problems fitting the side plate upper tubes with the LX moldings?
Anyone know how much to chop off to install the bumper? Also do i use my existing hardware to install it?
I don't see the point of the extra angle cut, I just cut them at the nut.
Here is the diagram from the install doc, if want the whole doc let me know.
I'm about to install my bumper this weekend. Is there any other debate on doing the angle cut like this or the straight cut just behind the second nut?
I used a sawzall on mine. It cut like buttah. I did the little angle thingie too, but it probably wasn't necessary...Are you using a sawzall to make those cuts? Or a cut off wheel on a grinder?
Same here. Have a couple extra good blades on hand. And, yes, those measurements you listed are correct @rockstate45 .I used a sawzall on mine. It cut like buttah. I did the little angle thingie too, but it probably wasn't necessary...
