4x4 Lo Switch (1 Viewer)
Cologne, MN
Is there a switch on an 87 tcase that indicates if you are in 4 lo. and if there is, does it switch to ground.
My LS harness needs a signal for 4lo for the transmission to shift correctly. The wire is switch to ground.
If not, I will have to add a manual switch to switch to ground for this wire.
I don't think so.
There is no switch on the case that triggers when shifting into 4lo. It triggers when shifting to 4wd.
Bummer...I’m out of holes for switches:)
My '86 FJ60 has an FJ62 transfer case, the rear case half has provisions for the L4 switch, along with the detents in the shift fork shaft. I converted the transfer case to manual front drive engagement so didn't need the switch for it's original purpose. I wired it to a new indicator light in the dash.
Does the 1987 60 case have the same provisions? I have a 4WD switch I could put in from another case if it would work
Pretty sure it doesn't - only on the FJ62 with vacuum shift transfer.
