4wd indicator switch leak!
Hampton Bays, NY
Anyone had this happen...mine is bleedin' nice clean gear oil...drip drip.....tried to snug it up but don't want to over tighten it....is there a way to seal it up??? Thoughts?
Thanks
Ummm what switch are you talking about? The only 4wd stuff in the cab has wires....
but there is a sender down on the transfer case that tells the light in the cab when to light up... that's probably what is leaking.
I'd pull the switch, clean the threads and see if you can install a gasket or o-ring.
