4wd help
Discussion in '60-Series Wagons' started by fowldarr, Feb 27, 2007.
  1. fowldarr
    fowldarr
    825
    5
    Feb 15, 2006
    SE Idaho
    Hey, I put my 60 in 4wd this morning, drove it to work, stuck to the road like a champ. But now it doesn't want to shift out of 4hi. It's stuck. Any ideas, I tried putting it in reverse and backing it up and rolling it forward. I tried forcing it, putting it in neutral, etc. etc. etc. Any tricks?
  2. fowldarr
    fowldarr
    825
    5
    Feb 15, 2006
    SE Idaho
    I need to drive home tonight? anybody?
  3. tclndcrz
    tclndcrz
    989
    1
    Mar 30, 2003
    Charleston SC
    are you sure its not in 4lo? i got confused one time when i hit the button to turn 4wd off and it wouldnt disengage. turns out i was still in 4lo.
    you can always unlock the hubs if you need to be out of 4wd for driving. the driveshaft may still spin but you wont have bad mileage or tire wear
  4. roscoFJ73
    roscoFJ73
    14,757
    Media:
    3
    Albums:
    1
    1,260
    Jul 22, 2003
    Perth Western Australia
    Its not really designed to be used on road unless its slippery all the way.
    Try reversing and pushing the stick at the same time.
    I suppose it would be ok to unlock the hubs and drive home.
  5. cruiser88
    cruiser88
    11,874
    Media:
    3
    Albums:
    1
    73
    Feb 21, 2006
    Winston Oregon
    try taking it out driving very slow.sometimes ive seen it need just a couple of quick bursts of the gas pedel to also get it out:beer: keep us posted
  6. REKCUT
    REKCUT SILVER Star
    3,647
    Media:
    103
    Albums:
    4
    91
    Jan 5, 2005
    Rogersville, Mo.
    Sometimes I have to hit mine with my hand after moving forward. I am not able to push it but if I kind of pop it, it will come out of 4 wheel. Can you go to low?
  7. REKCUT
    REKCUT SILVER Star
    3,647
    Media:
    103
    Albums:
    4
    91
    Jan 5, 2005
    Rogersville, Mo.
    Also you can unlock the hubs and drive it home
  8. jreed32152
    jreed32152
    212
    Apr 27, 2005
    Boise, ID
    My guess is your acuator solenoid went bad. Do a search for it. I think the common fix is mac valves. You can also swap the vacuum hoses to disengage. I have to do this every time I want out of 4 wheel drive.
  9. jreed32152
    jreed32152
    212
    Apr 27, 2005
    Boise, ID
    Where in SE Idaho are you from?
  10. John McVicker
    John McVicker SILVER Star
    2,167
    414
    Jul 11, 2005
    Big Pine, CA
    This never fails for me. Sounds crude/rough... but never fails. You said you did this but do it with more force. Put it in reverse....POP the clutch.. really pop it & push forward on the t/case shifter @ same time. Might need to do same in 1st gear.. then repeat reverse again.
    Sometimes doing the reverse thing in low 4 but with not as much pop. & then repeating the above. Be certain you have oil in t/case.
    Good luck, John
  11. fowldarr
    fowldarr
    825
    5
    Feb 15, 2006
    SE Idaho
    Thanks Guys, I was able to get it by reversing down slope in the parking garage. It popped right out. And just for clarification the roads were a virtual ice skating rink this morning, 5 slide offs and one head on in the 5 miles to work. But it all melts by afternoon. Jreed, I'm in Pocatello, how's Boise treating you? PM me if you're ever in the area. Thanks again....Case closed.
