4spd transfer case w/3spd gears...looking for rebuild info/tips.
san pancho, ca
Yes, I did a search...I did find some info on the following site :
http://www.toepper.net/Landcruiser pages/4_speed_trans_3sp_xfer.htm
I have never done a TC rebuild before, so I may just pull it and give it to a shop.
Does anyone have any info/experience on this subject?
As long as I don't run out of beer, could a rebuild be done in a weekend?
I have started a parts list, which I would need regardless If I rebuild it myself or not.
Please let me know If I am missing anything...thanks,
manny
Transfer Case Parts list
beer
3spd rebuild kit (does this normally come w/gears?)
4spd topcover oil seal
I didn't do a rebuild but I tried to replace the output shaft when I installed my toybox. There is a special tool required to remove the rear seal bearing race. It is not availble by itself from Toyota, only as part of a SST package that runs $$$$$$.
I have read a lot of web sites on how to get the seal/bearing out, the most sucessful seems to be cutting the O/P shaft and using a std bearing puller. Thats fine if you want to replace the shaft as I did but won't work for you. IIRC Someone on this board has the SST and loans it with a deposit.
(I eventually had a shop remove and replace the shaft. )
:doh: I was thinking transmission.
Was going to do the same thing myself but decided not to. Biggest question I have for you is, what is this thing going behind, 4 speed or 3 speed tranny. If it is a 4 speed then you will need the kit that you can get through some of the venders on here. If you are putting it behind a 3 speed then all you should need are the bigger spacers for the idler gears. And No no rebuild kit itself has come with gears, not to my knowledge anyhow. Someone out there might know some different things. Just my findings. I ended up just finding a different 4 speed and am going to build it. And these things can be built in about half a day.
HTH
The transfer case in question is in the truck, behind an sm465.
I got both of them from vortec-cruiser last year:
sm465, plate style adapter and 3spd gears already in 4spd case.
I love the combo :D
I'm just not crazy about the noise that appears to be getting louder from the tcase.
I'm Planning on seeing Georg at Doug's wrench-fest Dec. 10th.
What do you think they'll say, If I show up w/all the parts and gear-oil :D
See, that is where it gets trickey...
What is your ability before beer?
How rapidly does your abilty tank once the first beer is opened?
How many beers per half hour do you normally consume per given project?
How many other people will be there consuming?
How many of these other people are there to " help " or heckle?
Have you ever been into a tcase before?
Too many variables...
I would get A LOT of beer.....that way, no matter what, you know what you have.
As Charlie stated, a tcase is not that big of a deal, and you will need to have extra thrust washers for the counter gear set.
I am not aware of a tcase rebuild kit that includes gears...
If you need gears, I would look at an Orion. :)
Good luck!
-Steve
COMPLETLY dependent on how much beer you have with...
three-four cases is a good start...unless you are a two-case guy yourself ;)
Good luck!
-Steve
Pin_Head said:
Rebuilding a transfer case is a piece of cake and doesn't require any special tools. The 3sp idler gear will need some extra shims at the rear to fit in the 4sp case.
Damn, I was thinking transmission. Even an idiot like me can re-build a t-case, the tedious part was setting the preload.
Manny, I am doing that rebuild now. I have all the three speed gears in the 4spd case with no prolbems. 3spd shims for the idler gear is necesary and the brass washers also. That was all easy to do with a little planning and grease to hold the shims in place on the idler gear. That was a first me also. YOU CAN DO IT! Just give me a call if you have any questions.
I'm going to give Gary (Mudrak) a call and order the parts today...thanks Bill.
I wonder how much the kid will charge me to borrow her digital for documentation purposes :D
Manny , Where you at ? Bring it up to Santa Rosa and we'll do it. Easy in a weekend. Once it out truck it goes like butter. It is when you pull the idler and see the chewed up case that you wonder if this case has streched ??????? This being the real issue. Rebuild easy , getting lucky and having case been tight is another story. Have ole one eye check it , it will be half right then....
Idler shaft and idler bearings,
Front and rear output bearings allong with shims and races.
If your going to do it right replace the Hi and low output gear bushings which require a press.
Input bearing
output seals
Cone bearing
Inner front output shaft selector needle bearing
Seals and gaskets
And the most inportant is a t-case saver. To make sure it all stays together.
Do it right once and you won't need to do it again for 40k. Do it the other way just replacing the front and rear output bearings and you will be kicking yourself in the future. Trust me I know.
Thanks for offer John, but Teapot has a press and is a bit closer then Santa Rosa.
I am definetly interested in doing right the 1st time, already running a tcase saver :D
I am now wondering if it might be better to look for an empty 4spd case...if they exist?
I have my original 3spd w/guts sitting in the garage...just wondering how much a spare and the convenience is actually worth$$
Thanks for all the input guys,
manny
manny
Let me know I have an empty 4spd case left from my Orion conversion.
Does anyone have a 4spd tcase front output housing they want to get rid of (preferably a l8tr 27spline)?
I spoke w/Gary and am now planning on rebuilding my spare 3spd case, and running that.
The only problem is, I need to address the front output flange....as my drive-lines currently have the l8tr 4spd ujoints/flanges on the tcase side.
It looks like I can just swap-out the front output flange to a 10spline 4spd flange or drop-in a complete 27 spline front shaft/housing...
tcase tech may be found here:
http://www.kinzers.com/don/landcruiser/tcase_tech/tcase_tech.pdf
thanks
Manny , I think you will find the 10 spline 4spd. flange to be just slightly diff. than the fine sline 4spd. flange. IIRC you could put the 3spd. driveline ends onto your ujoints there by having the 4spd. pattern at the axle and the 3 spd. at transfer case. IIRC it is even one step easier to just get some 3 spd drivelines and pull the slip apart and slip it onto the other half from 4spd. driveline.
