4Runner (2007) Heated Seat Add-On (1 Viewer)
Colorado
I've been searching for some detailed information about adding heated seats to a 2007 4Runner SR5. There's not a lot of information based on search here and Google. Ideally I would like to buy a kit for the two front seats that comes with rocker switches similar to the OEM ones that can be placed in the center console switch blanks. Also, what is the best method to wire the power to ACC? I really don't like hacking factory wiring, so the cleaner the better. I assume they are probably need at least 5 or 10 amps each.
If someone could please point me in the right direction, that would be great!
An aftermarket heated seat kit is likely your best bet, and you can always buy OEM switches and wire the kit into them, which is what I plan on doing with my 80 series. Aftermarket kit will come with instructions, then you just need to figure our the wiring on the OEM switches.
I looked around some more last night. It appears the Rostra kit once had the rocker style switches, but now have the scroll type. If their switch fits the factory blank, I'll probably just go with that. It's for a family member, so they probably won't care. I just prefer the Toyota rocker switch for 2 mode heated seats since I usually turn it completely off after the seat warms up.
