455 Fj60 (1 Viewer)
Brandon MB
I am looking for any info, helpful tips, or the whole story.
I am going to put a 455 and TH 400 into my 1983 FJ 60. It has a leaf over and a shackle reverse, and a 2 in body.
I have e-mailed Marks Adaptors and Advance Adaptors for Kit info.
Floor consul and shifter for TH 400 ?
Will the Olds power steering pump work or will I have to use Toyota ?
Alternator ?
Motor mounting ?
Transmittion mounting bracket ?
Has a York air conditioning pump, that I would like to use for on board air.
Thanks in advance for any info.
Look in the tech pages at the V8 conversions. Most use a Chevy V8 but for the most part you're doing the same things. Motor mounts and trans mounts will be custom. I'd use a turbo 400 to a NP203 gear reduction box to the stock Toyota t-case. Pretty standard stuff there. GM alternator is an easy way to go. The Olds P/S pump will be fine with some custom hoses. Not sure if Olds ever used a York compressor in one of their cars. Probably have to make custom mounts for it to work on a 455. I'd guess there are a couple exhaust manifold choices around that would work with the Cruiser too.
Otherwise it's nothing more than some cutting and welding...
Good luck and take lots of pictures!
Nick
Lokar makes a slick brushed aluminum floor shifter for the TH400.
