45 wont go into reverse (1 Viewer)
Vancouver, Canada
Website
www.jjadventuretours.com
Won't go into reverse unless engine is shut off (4 spd tranny). Goes into 1st/2nd et ok. Where to start looking? Is there a synchro worn? Clutch needs bleeding/adjusting? or?
Howdy! All 4 forward gears have syncros. Reverse does not. Sounds like a clutch adjustment. Maybe need to lengthen the rod from the slave to the clutch fork. Or, may have worn clutch master/slave. John
Put it into second gear, and then put it into reverse...
Does it still make noise?
