41010 filter on the 2UZ?
Discussion in '100-Series Cruisers' started by Pskhaat, Oct 26, 2005.
  1. Pskhaat
    Pskhaat
    2,631
    4
    Aug 19, 2003
    Morrison Formation
    Hey, just getting my first set of stuff done on my newly acquired 100. Does the standard 41010 oil filter fit? It looks like it may be quite cramped in there.
  2. powderpig
    powderpig SILVER Star
    1,025
    23
    Jul 12, 2005
    Boulder Foothills, CO
    If this is the big old oil filter for the early f(2,3) and early 1FZ engines, No it will not fit. You need to source a fliter that was designed for the v-8. I would say toytota in most cases, but do not like the fact they went back to a paper element just to be competive with oil change places. That said it still meets factory warranty requirements for the oil change internavals set forth in the owners manual. If you search in the 80 archives on filters you may bring up lots of discussion on filters and what others may of done to get a more advanced filter. My self I got a couple of cases of filters when they discontinued the 20004 filter that was sythentic made in japan. good luck robbie
  3. shocker
    shocker
    1,185
    3
    Apr 10, 2003
    Kansas City, MO
    Just changed the oil a week or so ago in the LX, and I used a WIX. Can't remember which one, exactly, but it was whatever the WIX catalog recommended.
    WIX (same as NAPA Gold) are the highest rated filters other than certain OEM Toyota ones, which really aren't even available anymore.
    Anyway, they look pretty damn small compared to the ones in my FZE.
  4. ff347
    ff347
    958
    Media:
    5
    Albums:
    3
    306
    Nov 16, 2004
    Simpsonville,SC
    NAPA Filters Oil Filter (Gold) FIL 1348 $ 5.79
    Scott
  5. Pskhaat
    Pskhaat
    2,631
    4
    Aug 19, 2003
    Morrison Formation
    To kick a very redundant topic. Okay, the 20004 and 41010's are the same thread and ring diameter, too bad Toyota changed mfg's to the YZZD3s. Robbie, you're right Toyota's `official' statement is that it meets their warranty req's which in it statistically will get you to the end of the warranty I'm guessing.
    M1 filter # is M102
    I'll check out the Wix :)
  6. powderpig
    1,025
    23
    Jul 12, 2005
    I beleive in some ways it will get you through there design period for the engine. So If said engine is designed to go 300k miles, then if you do the oil changes and filter when it states and use a good oil, the engine should last the design period. These filters are used on many models of engines and in far worse conditions in other parts of the world. The engines in these parts of the world hold up well under those conditions using these filters. So if I had a choice between toyota thai filter and a fram, I would chose the toyota filter.
    AS for the size, I think the overall diameter of the big filter will not clear the oil catchement that the engineers put on the 2UZ engine. good luck on your choice. later robbie
  7. Jim_Chow
    Jim_Chow
    2,479
    14
    Apr 28, 2003
    Turquoise Trail, N NM
    The -20004's are still available in Japan for 2000 yen each. Both the YZZD3/20004 will fit a lot of Toyota engines. I'm using the YZZD3's on a 22re. It's the same thread/diameter as the el cheapo OEM filter used on US Toyota passenger cars like the Camry/Corolla, so you just need clearance for the extra filter length.
  8. Pskhaat
    Pskhaat
    2,631
    4
    Aug 19, 2003
    Morrison Formation
    Yep, just went with an M1-102 filter. I've never driven a vehicle above 300k, but I am a true believer in good oils/filters, even my commuter Ford (running M1) has a couple 100k without a touch of problems.
    I'll send the oil in for analysis on this new-to-me 100 and we'll see where any issues lie. I'm generally not that anal as you know, but it will give me a good place to start. Let's start with the fact that I had to use a breaker bar to get the oil pan plug out and smash holes in the Fram filter on there to turn it off :O
    It actually wasn't the drain lip that caused the issue, but a portion of the frame down there that angled the 41010 and the M1-1301 just enough to not catch the filter threads.
  9. bjowett
    bjowett
    3,767
    1,562
    Oct 28, 2002
    Western Massachusetts
    The large filter will not work on the V8 due to a larger O-ring diameter. It will weep oil and probably has the potential to blow out the ring.
  10. tabraha
    tabraha Hello My Name is: TAD SILVER Star
    2,519
    665
    Aug 20, 2003
    South Carolina
    Search for some UOA's that have been posted on here or at bobistheoilguy.com if you need some comparisons. I run the M1 filter and M1 5w-30 with great results. My UOA is in this forum somewhere if you need it.
  11. calamaridog
    calamaridog
    2,607
    22
    Jun 6, 2003
    Cuyamaca, CA and Las Vegas, NV
    The M102 is small. The M209 is larger, has the same specs, costs the same, and fits:) I've been running the M209 on my LC and my buddy has run the M209 on his Tundra for 150,000 miles.
  12. Pskhaat
    Pskhaat
    2,631
    4
    Aug 19, 2003
    Morrison Formation
    Yeah, just found that thread :doh: oh well, in 6 months I'll put on the M1-209
