Does anyone know what the differences are, if any, between fj40 4spd. transmissions & fj60 4spd. transmissions? Is there any advantages in installing an 83 fj60 4spd. into a 78' fj40?
Note: This feature currently requires accessing the site using the built-in Safari browser.
So then it wouldn't help with hwy speeds at all would it!
The 8/80 and later 4 speed have a 19 spline tailshaft and require a split transfer case. The early 4 speed have a 16 spline tailshaft and require one piece transfer case. So you have to have a matching transfer case.
Has anyone installed an h55f tranny in a 40? I know that they cost twice as much as a torque splitter though.Nope. All of the 3 speed and 4 speed transmissions have the same 1:1 ratio in the top gear. If you want some highway help, you would have to go with some sort of over drive setup, a h55 5 speed or different gearing in the axle. I am not sure if there is much help either from the different years transfer cases.
Do the OverDrive set ups hookup fairly easy and are they hard to find ? I would love to have that hwy gear on my 3speed.![]()
AA has the Ranger torque splitter that bolts onto the front of the 4 spd transmission but I'm not sure if it mates to the bellhousing. Not sure if it's just for a V8 conversion that retains the stock transmission or if you can use it with the 2F.TheH55F is a five speed transmission not just a overdrive. There were a few overdrives available years ago for the 3 and 4 speed with the one piece transfer case. Fairey was the most common.
Yeah, I was reading their parts catalog and it doesn't say anything about the 2F, just the LC 4spd. Think I'll give'm a call tomorrow and get a definite answer.Don't know the answer to that question either. The only ones I've seen were made to a V8.
