SOLD 40 series raised gearbox cover (H55 conversion) (2 Viewers)
FJ40GURU
Supporting Vendor
Australia
Raised gearbox cover
Removed from a later model (83/84) HJ47 with 4 speed.
It’s a raised cover but to accomodate H55 5-Speed gearbox, The transfer case bolt patterns needs to be moved down a bit I believe. Comes with gearbox boot.
John @Living in the Past can shed more light on this.
$225 shipped.
One bolt is snapped at needs to tapped out.
The transmission cane is in the same place on the 83/84 inspection cover. The transfer case opening is around a inch further back on the five speed. Other than that they are the same
To potential buyer: If you're going to use a floor mat, then it'll cover any added piece you attach to the transmission cover to cover the hole left when you cut the transfer case opening lower to accommodate the transmission that's moved back on the drive train. I decided to get one without the cut outs from City Racer but the one I got from him wasn't an exact fit and I have two bolt holes that aren't bolted down for that reason (fiberglass doesn't stretch :). If I had to do it over again, I would have left the extra metal frame the mechanic put over the cut out and not gotten the fiberglass cover because I ended up using a floor cover that hides the extra metal frame around the transfer case hole in the trans. cover.
