40 series gearbox into my cruiser ute
Hi guys.
I am planning a build at the moment and I want some really good gear reduction to run 39's.
I have been looking around the net for months now and have come across the Klune-V (Klunev.com) underdrive, and I think I would like to use one in my 60-series ute.
At the moment however Klune-V does not offer an under-drive to fit a 60-series 'long' 4-speed. Therefore I need a 'short' 4-speed to fit in my truck.
I hav found this information but I need to know if anyone out there in interminet land has any further info?
I was told that all of the gear boxes basically from 1970 to 1989 had the same bolt pattern onto the bell housing and input shaft (as long as I stayed with diesel gearboxes), etc, so you can mix and match these up to fit. Is this true? (do the petrol's have the same input shafts?)
The top of the gear box is removable. That is the whole top loader/selectors/gear stick. The 60 series Land Cruisers have a shorter gear stick than the 40 series, and it is located further back on the top loader section. I can put the 60 series gear stick etc on the earlie box.Next is the hand brake. On the 40 series, the handbrake is a transmission brake on the rear output shaft of the transfer case; on the 60 series, the handbrake is on the rear wheels. However I am using a 60 series split transfer case which will fit the Klune-V. So I am therefore planning on using a line lock in the rear brake hydraulic line as a hand brake, so that I can use my 80 series dif, and not have (mud grabbing, s***ty) diff mounted hand-brakes.
Any help will be massivley appreciated.
Cheers Davo.
