jestlurnin
78' 40. Sat in the garage all winter. Jumped in and tried to move it out of the garage. Fired her up in neutral and tried to shift into reverse to back out of the garage and got the ol' gear grinding sound. Well that's no good.
Turned her off and tried to shift. No dice wouldn't shift into any gear.
I bled the clutch from the slave thinking maybe it would help. It didn't.
Rocked the truck back and forth about 3 feet and now I can shift with the 40 off but if I fire her up I can't shift. No gear grinding unless I try and go into reverse just can not get the stick out of neutral with the 40 running.
Took the tranny inspection plate off and can see the clutch fork moving and the throw out bearing moving etc. but I have no idea how far they need to move and if that is even related.
Lastly, I parked her last fall with the transfer case in 4H and can not get it to shift up into 2H. Not sure if that tid bit of info is important but it seems like it might be. took the tranny inspection plate off and can see the clutch fork moving and the throw out bearing moving etc. but I have no idea how far they need to move and if that is even related.
Could my master be bad even though it is moving the clutch???
Can someone hold my hand here? Not sure what else to check/mess with to try and solve the problem. Seems like something is just stuck??
