'40 parts, '60 jack/mirror/dizzy (1 Viewer)
NorCal
'78 fj40 unless otherwise listed, all prices obo + shipping.
Please do make an offer. I want to move this stuff.
Not shown in the pictures is a 2f bell housing - $25 + shipping, which will suck, I'm sure.
1. Carb Insulator - $20 - SOLD
2. Emissions cover - $20
3. 3-speed inspection cover - $20
4. 4-speed inspection cover - Can barely see it. Great shape. - $20
5. Thermostat cover, for a 2f with no oil cooler - $10 PENDING
6. Air Injection Pump bracket - wider - $20
7. Thermostat cover, for a 2f with oil cooler - $15
8. Air Injection Pump bracket - narrower - $20 - SOLD
9. Water Pump, 2f, no oil cooler, use it for a spare - $10
10. fj60 dizzy, vacuum advance doesn't hold vacuum, bearings feel good - $75
11. Output Shaft end cover for one piece t-case - $5
12. Output Shaft end cover for one piece t-case - $5
13. Water House - thermostat housing for 2f - $20
14. non-OEM muffler pipe clamps. - free with anything else or any for $5
15. one piece t-case PTO cover - $10
16. 2f hard fuel lines - Seem ok, but I didn't try to fit them. Let's call them patterns, nut unions and brackets, but they'll probably work as is. $25 - SOLD
17. 2f fuel pump - run it or great spare - $40
18. carb spacer - ~1" - $20 - Edit: probably a minitruck brake booster spacer
19. fj60 driver's mirror - nice - $20
20. '78 fj40 headlight bucket, lamp bracket and 3 screws - $10
21. e-brake handle assembly - $25
22. '78ish carb throttle positioner - $5 - metal parts and spring, diaphram is gone.
23. '78 carb linkage bracket - bolts on with two carb mounting screws - $15 - SOLD
24. '78ish carb vacuum secondary actuator - $5
25. windshield hold-down bracket - $5
26. new rear brake cyl. - little surface rust, which one of the four? $10
1. fj60 jack and these three handle pieces - one piece missing - $25 - pending
2. heater hose routing (fj60?) - $20
3. drive shaft yoke - good u-joints - one fj40, one minitruck, one ? I can measure for you - $25 each
4. tie rod - 28 5/8" c-c (fj60?) - $20
5. 2f motor mount - $20
6. '78 tubular tire carrier bump stop - bent - I think easy to repair in a decent vise - $10 - SOLD
7. '78 front blinker parts - plastic housing is 100% - $10
8. 4-speed bell housing mount bracket, left side, pretty sure, those are the slave cyl mount holes, right? - $10
9. 2f motor mount bracket - (I have another pair too) - $10
10. rear spring plates with lower shock mounts - $25
1. Good pair of retractable belts - 1/2 shown - $50 - SOLD
2. Less good pair of non-retractable - plenty of rust on the latch plates, one belt is very ripped - $20 - SOLD
dibs on jack and handles.....
bump for a very nice numbering system, makes it easy to identify parts/desciptions
PM sent on carb insulator.
Ill take the 78 tubular bump stop for $10, #6 in pic 2.
Shipping to 76013.
PM me with total.
Sure wish you had a manifold sensor. I like the numbering system.
ill take #13 if you still have it and isnt cracked or retapped, shipped to 11215. PM your paypal email. thanks!
Do you still have the 4speed bellhousing/inspection cover???? 15-20 bucks for it plus shipping.
I got one for a 60 series for a 40 bell, and guess what not the right fit.
Eddy, do you still have item #7, thermostat cover (w/oil cooler)?
Probably. I can look on Friday morning.
I'LL TAKE #3 FJ40 YOKE AND #7 SHIPPED TO 91354
Which FJ40? The ones I have are for '76-'78, at least. #7 blinker parts? I'm pretty sure I still have them, but I'll have to check.
Where'd ya dig up the aluminum carb spacer? #18.
that's a new one on me..
