- Location
- United States
Well, it's time to clean out ye olde garage as I am running out of room to work
For any one in Eastern NC, in the New Bern, Wilmington, Raleigh triangle, I can drop it off to you. And Maybe out to Greensboro, depending if I have enough time. I live in New Bern and the
lives in Durham
Reasonable offers will be entertained
SOR front and rear Fender Flares, never installed and I'm pretty sure I have all the weather stripping and junk that came with them. $100 plus the rideSale Pending
Front and rear wheel caps and sleeves. The sleeves are un used, and the caps are a little scratched up but nothing too serious. $30 plus the rideSale Pending
Hard Top shelf, fits between the ledge on the factory hard top. $40 plus the ride
2F Valve Cover, used but in Ok shape. $20 plus the ride
Factory rear license plate holder. Is complete, I put it all together and went another direction and don't need it. Has light scratches in the paint, the way I got it from CCOT. $95 plus the ride
75+ turn signals, in good shape. No fading or cracks or scratches. I had them on the 40 for about 6 months before I went to a set of the older style T/S. One of the mounting nuts is missing and one of the tabs on the bottom is broken off, still mounts fine
$75 for the pair plus the ride.
DUI HEI Distributor with Mechanical Advance for the 2F. Used it for about a year and a half until I replaced the Weber carb and went to a dizzy with vacuum advance. $125 plus the ride
