Dazed
Blue's Driver
I have no idea if anyone else has posted this or found this before, but I wanted to share.
The Hopkins 43315 ($25 from amazon, $40 from autozone) wiring kit for 1984-95 Toyota pickups and 1995-2004 Tacomas can be modified ever so slightly to work with a 60-series land cruiser. The plugs fit the LC, but the wires are in the wrong locations. Taking out the wires from the plugs isn't too hard and requires about 15 minutes of time. I used a long straight pick to lift the catches to removed the blades and receivers from the connectors. Then you need to replug in the wires into the correct locations. I did not record LC location list. However, wire colors are below. Anyway, once all of this is done, the kit is a "plug-in simple" (Hopkin's saying) for the LC and adding a four wire trailer connector requires no splicing or anything else into the factory wiring harness.
Hopkins wire///Toyota Wire///Function
Green///Green-Yellow///Right turn signal
Red///Green-White///Brakes
Yellow///Green-Black///Left Turn signal
Brown///Green///Tail lights
White///Brown///Ground
