4 speed issues
Discussion in '40- & 55-Series Tech' started by Deny, Aug 16, 2005.
  1. Deny
    Deny
    3,919
    207
    Jan 18, 2005
    Fort St John, BC
    Hi all,
    On my long(15 hour) drive home from Cruiser Days, I had a problem shifting into 3rd gear. both from second and when downshifting from 4th. It would not go in unless I jammed it in with a little grinding. At idle it would work no problem, and I tried double/ triple shifting, and it helped a bit, but would usually kill my momentum up hill and I would have to hit 2nd. Today I drove to work, and without the engine warm yet, it worked perfectly, and I actually had more trouble shifting into second. What is up with that? did the highway drive do something to the 3rd gear syncro? heat up too much and not work? low on fluid (I will check today)? I have no clue about the inner workings of the trannies, but would like to know what is going on.
    Thanks,
    Deny
  2. cruiser_guy
    cruiser_guy
    11,197
    36
    Jan 20, 2003
    Wherever the truck stops!!
    You need to replace the plastic bushing that sits under the shifter lever. It's a $20 part and only requires that you pull the shifter and the old bushing out. You DON'T need to do anything to the tranny.
  3. Deny
    Deny
    3,919
    207
    Jan 18, 2005
    Fort St John, BC
    Sweet, thanks,
    I'll check into that.
  4. Deny
    Deny
    3,919
    207
    Jan 18, 2005
    Fort St John, BC
    anybody have a part number for this part,
    I haven't tried Toyota yet, but my brother did a few months ago, and said they couldn't get it.
    Thanks,
    Deny
  5. cruiser_guy
    cruiser_guy
    11,197
    36
    Jan 20, 2003
    Talk to Gord at Pim Pattison Toyota in Surrey. He knows the part I'm talking about.
  6. lone gunman
    lone gunman
    1,400
    15
    Aug 17, 2003
    granite falls WA.
    try www.sor.com look under trannys you will find them they arent that expensive but the handling fee will probably be more then the part. good luck!
