4 spd in 63 FJ45 swb
Does anyone know if when you put in a 4sp in a 66 down if there is a problem with the linkage for the TC when you put the clutch fork on the pass side.
In my 69 I put the fork on the drivers side when I put in the 4spd and it was a PIA.
Without the body on the frame I cannot tell if the passinger side will work.
Thansk Myrle
3_puppies
Helena MT
Myrle, when I put the one in my 65, I had to cut/notch gusset piece under the floor board to get enough throw. can't see it from above. How's the recovery going? Paul
Mill Valley, CA
i put mine on the driver side and just streched the hi/lo shift linkage to fit... oh and got some new vac line that was a little longer for the 4w drive
Thanks Guys, I think will put it on the drivers side It will probally be easier than the 69 was without a body on the frame. It just looks a little funky on the Fj40 but works fine.
Paul, Shoulder is doing good, went to the doc yesterday and he was suprised at all the movement I have with it. I think it was all the Fj45 small parts cleaning that has helped.
