The best place to start with this question is how does the full time 4wd work? Is there a dynamic power shift between front and rear wheels or is it always 40/60 power split?
With that in mind, is it safe to use 4-low on dry pavement or other surfaces? I know part time 4wd vehicles with a 50/50 split need the front end to have some slippage due to the gears not matching up correctly, otherwise you can grenade your transfer case.
Not many reasons you'd need 4-low on pavement but it it would be good to know.
and now with PT I have no center diff lock as its always locked when in 4WD and I still use it on the ramp
